November 9, 2017 at 6:06 pm
cpegg
SubscriberHi all
As part of my 5th year group project I am studying coating formations of Titanium Particles impacting a Titanium substrate at high velocity.
The simulation has been set up using the Laminar Solver with the Energy Equation enabled, the Dynamic Mesh setup for a deforming mesh at an input velocity of 1000m/s. When solved transiently the particle is seen to move towards the substrate as expected. However for some unknown reason the particle simply passes through the substrate as if it wasn't there. I have spoken to one of my supervisors about the issue to no prevail.
Would anybody have any insight into the issue? There are papers available that show what I'm trying to do is possible, but there is no information into how the simulation was setup.
Thanks.
November 9, 2017 at 8:25 pm
Raef.Kobeissi
SubscriberHello Whats the boundary condition on the substrate? It should be set as wall. If the substrate is represented as a meshed domain it will be treated as a fluid domain and the particles will just travel through it.
It would be great if you could provide some pictures and more information around your setup.
Best Regards -
November 10, 2017 at 8:03 pm
cpegg
SubscriberHi Raef
The substrate is set as a wall and the cell zone conditions for it are solid. The substrate is meshed (I have played around and haven't been able to remove the mesh on this section.)
The setup is simply a closed system, a sphere above the substrate, only one particle is present as this simulation is merely a proof of concept before I build it up and work towards the final model. Â
When using the post processor and viewing the time-step animation the particle simply passes through the substrate without even a hint of interaction, I suspect you are correct, and the substrate is being treated as a fluid domain. I'll look into it, can you think of anything obvious I may have missed? I'm no expert in CFD.
Thanks.
November 10, 2017 at 8:47 pm
Raef.Kobeissi
SubscriberI think the problem is with the dynamic mesh behaviour, could you please show me a pictuere of the mesh when the sphere goes through the substrate.
Thanks -
November 10, 2017 at 9:11 pm
December 6, 2017 at 10:22 pm
cpegg
SubscriberHi Raef
I have been looking over this issue for a few weeks now and I am still struggling to find a solution to the problem. Is there any insight you can add to this?
Thanks.
- The topic ‘Particle Impact upon a substrate (Thermal Spraying) using FLUENT’ is closed to new replies.
5814
