January 31, 2024 at 3:35 pm
JASH RANA
SubscriberHi I am trying to run a particle impact on substrate simulation, but I am running into an issue where my particle goes straight through my substrate. My particle has a 20 micron diameter and is travelling at 600 mm/ms. Im using mm, kg, and GPa for my units. I am using a surface to surface contact, with the Johnson cook material model. I have included a images of my contact set-up and material model parameter. Any help would be greatly appreciated. Thank you!
February 1, 2024 at 6:36 pm
Jim Day
Ansys EmployeeFor high velocity impact, you may need to reduce the time step as the default time step does not take into account initial velocity.  Distance traveled will beÂ
x = v dt
Let v be the initial velocity, x be some small fraction of your element size, say 1/100th the element size, and dt be the time step size you should not exceed.  You can use a curve (variable LCTM in *CONTROL_TIMESTEP) to set a cap on the time step size.
- The topic ‘Particle Impact Simulation Help’ is closed to new replies.
4713
1565
1386
1242
