LS Dyna
LS Dyna
Particle Impact Simulation Help
    • JASH RANA
      Hi I am trying to run a particle impact on substrate simulation, but I am running into an issue where my particle goes straight through my substrate. My particle has a 20 micron diameter and is travelling at 600 mm/ms. Im using mm, kg, and GPa for my units. I am using a surface to surface contact, with the Johnson cook material model. I have included a images of my contact set-up and material model parameter. Any help would be greatly appreciated. Thank you!
    • Alex Rycman
      Please consider following poitns:
      • In general particle method requieres *CONTACT_AUTOMATIC_NODE_TO_SURFACE
      • Please look at the BSORT position in Option card A.
      Which particle method are you using?
      Thanks,
      Alex
      • JASH RANA
        Hi Alex thank you for the reply, I am fairly new to impact simulations. I modelled the particle as a solid and then selected its nodes to create a segement. I used that segement and the surface of the substrate for the contact. Here are my MAT, EOS, and CONTACT cards. The TERMINATION time I am using is 1e-4 ms. I added the TIMESTEP card and kept default values. I am writing to the d3plot with DT = 1e-8 ms.
    • JASH RANA
      I have set up both particle and substrate as LAGRANGE_IN_SOILD. I created a partset for the particle and added it to LSTRID. Same for the substrate.
    • JASH RANA
    • JASH RANA
      Here is a link to my keyword file.
      My particle just dissapears when I try to check the d3 plot.
    • Alex Rycman
      Please note that Ansys employees cannot download or view any files posted on that forum.
      Could you describe your problem/what are you trying to simulate?  I am not sure about using *CONSTRAINED_LAGRANGE_IN_SOLID.
      Could you elaborate on particle disappearing in d3plots? Are they eroding or disappearing after first timestep? How does your total energy graph look like?
      Alex
Viewing 5 reply threads
  • The topic ‘Particle Impact Simulation Help’ is closed to new replies.
