October 1, 2024 at 2:30 pm
kiran.purushothamakeshavan
SubscriberHello,
I have written a UDF where I count the number of particles that hit a wall and gets stuck to it under certain conditions.Â
I see that the number of particles hitting this wall is 22k while I only count 4.5k particles at the inlet. Why do you think this might be happening?
/* reflect boundary condition for inert particles */#include#include "udf.h"#include "dpm.h"#include "mem.h"#include "sg.h"#include "stdio.h"#include "math.h"#define g -9.81#define mu 0.5#define NUM_UDM 7#define PI 3.141592654FILE *fp1;FILE *fp2;FILE *fp3;real FD(real diam, real velocidad){ return ((1/2) * 1.225 * 0.44 * M_PI*(((diam)*(diam))/4) * (velocidad*velocidad));}DEFINE_DPM_BC(bc_reflect,p,t,f,f_normal,dim){ real alpha;  /* angle of particle path with face normal */ real vn=0.; real nor_coeff = 1.; real tan_coeff = 0.3; real normal[3]; int i, idim = dim; //real NV_VEC(x); real posx, posy, posz; // real NV_VEC(x); real x[ND_ND]; real A[ND_ND]; Domain* d; real Area; real Flux_density, tem_MFR; real tem_MFR_2, Flux_density_2, Area_2; // FILE *fp1; real w, drag_force, F, nf, ff, ff123; Thread *tcell = P_CELL_THREAD(p); cell_t c = P_CELL(p); real relVel[ND_3], dvtdn, fluidVel[ND_3]; // mass of particles real tem_particle_dia = 0; NV_D(fluidVel, =, C_U(c, tcell), C_V(c, tcell), C_W(c, tcell));   //assigning fluid velocity components to vector NV_VV(relVel, =, fluidVel, -, P_VEL(p));       //calculating relative velocity of flow on particle by subtracting absolute particle velocity from fluid velocity dvtdn = NV_MAG(relVel);         //calculation of relative velocity magnitude // P_USER_REAL(p, 0) = FD(drag_force, C_MU_L(c, tcell), P_RHO(p), P_DIAM(p), P_MASS(p), dvtdn); /*Drag force*/ P_USER_REAL(p, 0) = FD(P_DIAM(p), dvtdn); /*Drag force*/ P_USER_REAL(p, 1) = dvtdn; // fprintf( fp1 , "%e %f %e %f %f %e %e\n", P_USER_REAL(p, 0), P_USER_REAL(p, 1), P_USER_REAL(p, 2), drag_force, P_DIAM(p), F, P_USER_REAL(p, 3)); real diameter_squared = P_DIAM(p) * P_DIAM(p); real area_term = (diameter_squared) / 4; real velocity_term = dvtdn * dvtdn; real constant_factor = (1.0 / 2.0) * 1.225 * 0.3 * PI; F = constant_factor * area_term * velocity_term * (10000000); P_USER_REAL(p, 2) = F; nf = C_P(c, tcell) * (PI / 4.0) * diameter_squared *10000000; ff = mu * nf; ff123 = ff; P_USER_REAL(p, 3) = ff123; fp1=fopen ("Impact-2-drag-data-mod.txt" , "a"); fprintf(fp1, "Area Term: %e, Velocity Term: %e, F (final): %e, Constant factor: %e, friction force: %e, Normal force: %e\n", area_term, velocity_term, P_USER_REAL(p, 2), constant_factor, P_USER_REAL(p, 3), nf); fprintf(fp1, "Pressure: %e,  ff123: %e\n", C_P(c, tcell), ff123); fclose(fp1); Message("Inside the first section"); #if RP_2D /* dim is always 2 in 2D compilation. Need special treatment for 2d   axisymmetric and swirl flows */ if (rp_axi_swirl)  {   real R = sqrt(P_POS(p)[1]*P_POS(p)[1] +          P_POS(p)[2]*P_POS(p)[2]);   if (R > 1.e-20)    {     idim = 3;     normal[0] = f_normal[0];     normal[1] = (f_normal[1]*P_POS(p)[1])/R;     normal[2] = (f_normal[1]*P_POS(p)[2])/R;    }   else    {     for (i=0; i      normal[i] = f_normal[i];    }  } else #endif  for (i=0; i   normal[i] = f_normal[i]; if(p->type==DPM_TYPE_INERT)  {   if (fabs(P_USER_REAL(p, 2)) < fabs(P_USER_REAL(p, 3)))  // Particle bounce: Aerodynamic force > Pressure force on particle. So particle must be resuspended to the flow.   {     for(i=0; i      P_VEL(p)[i] = 0;     P_USER_REAL(p, 7) += 1.;      posx = P_POS(p)[0];      posy = P_POS(p)[1];      posz = P_POS(p)[2];      P_USER_REAL(p, 4) = posx;      P_USER_REAL(p, 5) = posy;      P_USER_REAL(p, 6) = posz;      C_UDMI(c, tcell, 0) += 1.0;      C_UDMI(c, tcell, 1) += P_FLOW_RATE(p);      //P_USER_REAL(p, 8) += P_FLOW_RATE(p);      tem_MFR = P_FLOW_RATE(p);      F_AREA(A,f,t);      Area=NV_MAG(A);      // why do you have tem_MFR instead of      Flux_density = tem_MFR/ Area;      C_UDMI(c, tcell, 2) = Flux_density;     fp2=fopen ("Impact-Stick-mod.txt" , "a");     fprintf(fp2 , "tem_MFR: %e, Area: %e, Particle flux density: %f, Force due to aero (Fa): %f, Friction force (ff): %f, How many stick? = %f, x coordinate: %f, y coorfdinate: %f, z coordinate: %f\n", tem_MFR, Area, Flux_density, P_USER_REAL(p, 2), P_USER_REAL(p, 3), P_USER_REAL(p, 7), P_USER_REAL(p, 4), P_USER_REAL(p, 5), P_USER_REAL(p, 6));     fflush(fp2);     fclose(fp2);     return PATH_ABORT;    }   else   {    alpha = M_PI/2. - acos(MAX(-1.,MIN(1.,NV_DOT(normal,P_VEL(p))/                  MAX(NV_MAG(P_VEL(p)),DPM_SMALL))));    if ((NNULLP(t)) && (THREAD_TYPE(t) == THREAD_F_WALL))     F_CENTROID(x,f,t);    /* calculate the normal component, rescale its magnitude by     the coefficient of restitution and subtract the change */    /* Compute normal velocity. */    for(i=0; i     vn += P_VEL(p)[i]*normal[i];    /* Subtract off normal velocity. */    for(i=0; i     P_VEL(p)[i] -= vn*normal[i];    /* Apply tangential coefficient of restitution. */    for(i=0; i     P_VEL(p)[i] *= tan_coeff;    /* Add reflected normal velocity. */    for(i=0; i     P_VEL(p)[i] -= nor_coeff*vn*normal[i];     /* Store new velocity in P_VEL0 of particle */    for(i=0; i     P_VEL0(p)[i] = P_VEL(p)[i];    Â    C_UDMI(c, tcell, 3) += 1.0;    C_UDMI(c, tcell, 4) += P_FLOW_RATE(p);    P_USER_REAL(p, 8) += P_FLOW_RATE(p);    tem_MFR_2 = P_FLOW_RATE(p);    F_AREA(A,f,t);    Area_2=NV_MAG(A);    Flux_density_2 = tem_MFR_2/ Area_2;    C_UDMI(c, tcell, 5) = Flux_density_2;    P_USER_REAL(p, 9) += 1.;    fp3=fopen ("Impact-Bounce-mod.txt" , "a") ;    fprintf(fp3 ,"Force due to aero (Fa): %f, Friction force (ff): %f, Number of particles bounced: %f\n", P_USER_REAL(p, 2), P_USER_REAL(p, 3), P_USER_REAL(p, 8));    fflush(fp3);    fclose(fp3);    return PATH_ACTIVE;   } } return PATH_ABORT;}ÂÂI tried debugging this but I do not seem to understand why this might happen, your suggestions would be greatly appreciated.ÂThanks,
KiranOctober 1, 2024 at 2:56 pmRob
Forum ModeratorYou're tracking parcels, not particles, but that's a definition issue. Is the model transient? Have you run the particle tracking more than once? Note, I'm aware that particle and parcel are used interchangeably (and incorrectly) within Fluent, but as that's historic won't be changing anytime soon.Â
October 1, 2024 at 10:55 pmOctober 2, 2024 at 1:10 pmRob
Forum ModeratorYou're tracking parcels, each parcel follows the trajectory of the particle but has mass etc of the parcel. Check the DPM part of the manuals and possibly some background reading. Note, a parcel usually has significantly more mass than a single particle but that's not always the case. In Fluent particle is used incorrectly in place of parcel in many instances.Â
I don't know what your injection is set as, but you're releasing some parcels every flow time step. If it's a surface release from the inlet you're releasing a parcel for every facet on the inlet every fluid time step. That may explain the parcel count you're seeing. Â
Viewing 3 reply threads- You must be logged in to reply to this topic.
5849
Ansys does not support the usage of unauthorized Ansys software. Please visit www.ansys.com to obtain an official distribution.The Ansys Learning Forum is a public forum. You are prohibited from providing (i) information that is confidential to You, your employer, or any third party, (ii) Personal Data or individually identifiable health information, (iii) any information that is U.S. Government Classified, Controlled Unclassified Information, International Traffic in Arms Regulators (ITAR) or Export Administration Regulators (EAR) controlled or otherwise have been determined by the United States Government or by a foreign government to require protection against unauthorized disclosure for reasons of national security, or (iv) topics or information restricted by the People's Republic of China data protection and privacy laws.Please Login to Report Topic
Please Login to Share Feed
Edit Discussion
[bingo_chatbox]The Ansys Learning Forum is a public forum. You are prohibited from providing (i) information that is confidential to You, your employer, or any third party, (ii) Personal Data or individually identifiable health information, (iii) any information that is U.S. Government Classified, Controlled Unclassified Information, International Traffic in Arms Regulators (ITAR) or Export Administration Regulators (EAR) controlled or otherwise have been determined by the United States Government or by a foreign government to require protection against unauthorized disclosure for reasons of national security, or (iv) topics or information restricted by the People's Republic of China data protection and privacy laws.
