April 9, 2020 at 7:18 am
Benjamim2020
SubscriberHello, i'm doing an analysis of a prestressed beam, this prestressing is made with structural stell cable, the beam is a metal beam of the "I" profile type.
I'm fiding some erros, i already tried to exchange the beams for cables in the gometry confifurations in definitions - modal type.
Attached is the imagens with the erros, i wanted some help, thank you!
April 9, 2020 at 11:36 am
Aniket Chavan
Forum ModeratorFirstly switch on Large Deflections in Analysis setting under solver controls.
For the next step, do a Modal analysis first to check the sufficiency of your BCs and contacts. If you see no zero-frequency mode then proceed to the static analysis.
-Aniket
How to show full resolution image
How to use Google to search within Ansys Student Community
April 11, 2020 at 12:36 am
Benjamim2020
SubscriberÂ
Hello Aniket. Good evening! I understand, I will try to do what I said, thank you very much.
April 13, 2020 at 7:54 pm
Benjamim2020
SubscriberHello good afternoon!
When and why to activate the large deflection?
April 15, 2020 at 6:58 am
Aniket Chavan
Forum ModeratorDid you do the modal analysis first and checked for rigid body modes?
Why activate large deflection: because you are getting a warning for the same!
Please check the following blog from our channel partner for more information:
https://www.padtinc.com/blog/to-use-large-deflection-or-not-that-is-the-question/
-Aniket
- The topic ‘Parsing error’ is closed to new replies.
5754
