March 22, 2024 at 9:53 am
March 22, 2024 at 3:06 pm
March 22, 2024 at 3:29 pm
March 25, 2024 at 4:51 am
March 28, 2024 at 1:56 pm
Devendra Badgujar
Forum ModeratorHello Sai,Â
You cannot parametrize the projections of a sketch. Projections are derived from your sketch and are aligned to the sketch dimensions.Â
You can create sketch dimensions from the Constraints group under Sketch Tab and you will need to keep the Block recording option active to record this step and than you can parametrize the dimensions:
Let me know if this helps.Â
Devendra
Viewing 4 reply threads
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
1494
1376
1209
