Parametric Study updates entire workbench project, how to prevent it ?
    • Pawel Cebula
      I'm working on a parametric study (Static Structural) for a submodel of a main Statuc Structural component in the same Workbench project.
      The main Structural Component has results up to date, but some of its feeding components need update.
      When I try solving the design point, it causes domino effect update on entire project file which in my case takes ages. Is there a way to solve design point without updating the whole project file?
    • ashish.khemka
      Try selelcting the requireried analysis system and then click on update. For example you have 5 analysis systems (A to E) and you want to update just 3 of them then select one and ctrl and select the remaining two and then hit on update button.
      Ashish Khemka
