July 23, 2021 at 12:43 pm
ataylor
SubscriberIs there a way to create parameters in sketch mode? For example, I create a line in sketch mode. Is there a way to parameterize the length of the line? Thank you.
July 23, 2021 at 10:04 pmpeteroznewman
SubscriberAre you going to convert that line to a beam elements?
Or does that line become a face of a body when the sketch is pulled into a solid?
It would be easier to offer useful suggestions if you show what you are trying to do.
July 26, 2021 at 12:37 pmataylor
SubscriberThe line would become the face of a body when pulled. Or, I might choose to revolve it around an axis. Not trying to do anything specific yet; just trying to learn. Thanks.
July 26, 2021 at 9:37 pmpeteroznewman
SubscriberAfter you use the pull tool, it is very easy to add a parameter while moving the face of the solid. The P button shows up while using the Pull tool.
Viewing 3 reply threads- The topic ‘parameters in SpaceClaim’ is closed to new replies.
Innovation SpaceTrending discussions- Project lines/edges into a face with the direction normal to the face
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
Top Contributors-
4062
1487
