April 18, 2024 at 9:52 pm
William Phillips
SubscriberI'm trying to run a parametric study in Fluent over a range of several velocity values, which means my boundary layer initial height will change with each design point. However, I can't find out how to paramaterize this value in Ansys meshing or Fluent meshing. Is this possible, or will I have to mesh each design point individually?
April 19, 2024 at 5:07 am
Keyur Kanade
Ansys EmployeeYou can use last ratio option in Inflation in Ansys Meshing in which you can parameterize first layer height.Â
Please go through help manual for more detailsÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
- The topic ‘Parameterizing Boundary Layer Initial Layer Thickness’ is closed to new replies.
