TAGGED: command-snippet, parameterize, torsional-stiffness
February 20, 2022 at 10:15 am
lbtung248
SubscriberHello!
I am using a torsional spring combi250 and i want to parameterize the stiffness constants K1 to K6. As far as i know, i must assign these constant values to input arguments of the command snippets ARG1 to ARG9. Which command can i use to assign these values?
February 21, 2022 at 4:22 pmAshish Khemka
Please see if the following post helps:
How to parametrize the stiffness coefficients of a bushing joint? set the values to Parameters set ÔÇö Ansys Learning Forum
Regards Ashish Khemka
February 27, 2022 at 9:38 amlbtung248
Thank you for your reply, however within the post you referred to, i only find information to assign stiffness coefficients for Element 184 using TBDATA command. I tried the same command for Element combi250 and it didnt work.
For TBDATA command, my element should be a joint connection type, where as the element i have now is a spring connection. I think that is why it didnt work.
Do you have any idea?
Viewing 2 reply threads- The topic ‘Parameterize Springs Stiffness Constants in Mechanical Command Snippet’ is closed to new replies.
5739
