November 25, 2021 at 3:27 pm
Eoin
SubscriberHi all,
I am trying to create parameters so that I can change the angle and move a segment of asketch laterally, as highlighted in the first image (changed laterally from 12 mm to 10mm and the angle from 15°-11°). While the shape is a sketch I can change the dimensions, but once I convert it to a surface I am unable to alter the angle, what should I do to convert the dimensions to parameters?
November 25, 2021 at 6:57 pmpeteroznewman
SubscriberNovember 26, 2021 at 10:26 amEoin
SubscriberThank you very much for answering so quickly. It is very much appreciated!
Viewing 2 reply threads- The topic ‘Parameterising an angle for a 2D Surface, Spaceclaim’ is closed to new replies.
5934
1306
