November 5, 2024 at 11:18 am
H.Shirzad2
SubscriberSo I am trying to create a calculation in the sweep setup. This error keeps coming. Failed to extract solution data for 'SlugHeight='1mm'' at 'AmpTurns' with value '100A', please exclude this sweep value from the calculation range. This is the example from MAXW_Intro_Param_3DMagnetoCS1_solved in the ALH. Can you please help me with that?
November 12, 2024 at 5:20 pm
Tamami Yamanaka
Ansys EmployeeHello,
The error suggests that there is a mismatch between the parametric sweep setup and the actual design parameters or analysis setup. This can occur if there have been changes to the setup that were not reflected in the parametric sweep options.Â
Please review your sweep setup to ensure that the calculation ranges in the parametric sweep match the design options and that all entries in the Calculation Tab exist in the design, or clean up solutions and re-create the parametric sweep setup.Tamami
