Photonics
Photonics
Parameter sweep of optical power in INTERCONNECT
    • m.belchovski
      I have a problem when trying to set up a single parameter sweep for my CW laser optical power in INTERCONNECT. As you can see from the picture below, where it is shown how I set my sweep, I set the starting point of the sweep -10 dBm to 0 dBm. But when I run the sweep, I get the following error: "Error: prompt line 1: in setnamed, the value supplied is not acceptable for the property 'power', it may be out of range, have incorrect dimensions or not be found in the list of choices ". When I put value from sweep from 0 to 10, it works normally.
      How can I solve this problem?
      Thanks.
    • m.belchovski
      Or the sweep start, and stop should be in absolute power units (W)?
    • Dev
      Hello, Please try power in W (SI units) not in dBm.
      Thanks and regards
      Devika
  • The topic ‘Parameter sweep of optical power in INTERCONNECT’ is closed to new replies.
