August 15, 2024 at 10:23 am
Noura Mansour
SubscriberHow can i enter the output parameter set to be a chart between force and displacement so any change in geomtry parameters will change in this chart ?
as i want to export it to matlab to make optimization -
August 16, 2024 at 12:16 pm
Saurabh Patil
Ansys EmployeeHiÂ
If you wish to plot a chart between force and displacement:Â
1. Create a directional deformation result. This will be one of the parameters you want to plot in your chartÂ
2. Insert a new Chart and Table from the toolbar. This is done by clicking on the icons in the toolbar that allow you to add a new chartÂ
3. In the details window, select '0 objects' in the Outline Selections and choose 'Force'. Then, while holding down the control key, select 'Directional Deformation' and apply your selectionÂ
By setting up the chart in this way, any changes you make to the geometry parameters that affect force or displacement will be automatically updated in the chart, allowing you to visualize the impact of your modifications.Â
Saurabh
