April 2, 2024 at 12:01 pm
Tim Dietl
SubscriberHello everyone,
I would like to calculate ARCCOS() and TAN() with parameters but I don't find the parameter language. Is that even possible?
Tim
April 2, 2024 at 1:44 pm
Akshay Maniyar
Ansys EmployeeHi Tim,
It would be great if you could share more details about what you are trying to do. We can do mathematical operations as user-defined results. Please check the below Ansys help link for more details.
User Defined Result Expressions (ansys.com)
Thanks,
Akshay Maniyar
April 4, 2024 at 6:17 am
April 4, 2024 at 9:45 am
Akshay Maniyar
Can you tell me what is the unit of P34 parameter? For trigonometric functions, the unit of quantity should be [deg] or [rad]. Please check the below Ansys help link for details.
Expressions, Functions, Quantities, and Units (ansys.com)
Thanks,
Akshay maniyar
April 4, 2024 at 9:49 am
Tim Dietl
SubscriberHello Akshay,
thank you for your help. The problem is solved.
acos(P34/800[mm]) works.
Tim
April 4, 2024 at 10:10 am
Akshay Maniyar
It is great that your issue is resolved. I will close the thread. If you have any new queries, you can start a new query.
Thanks,
Akshay Maniyar
- The topic ‘Parameter language for ARCCOS() and TAN()’ is closed to new replies.
- Contact stiffness too big
- Test post on Forum – LLM response – SC
- 13-Node Pyramid Element Shape Function
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
4512
1494
1386
1209
