Parallel computing for loop in APDL
    • Guojz16
      There are a lot of nodes on a part surface. A concentrated force is applied to one of them. We can get the deformation of all nodes. Now the concentrated force is applied to all nodes in turn, and I want to obtain the result. The function is implemented by a loop program. I want to speed up the computation of the program. I wonder if we can complete the loop by parallel computing in APDL.
      Answer to the question will be very helpful.
      With regards
      Guo
    • ErKo
      If you mean multi/parallel-processing:
      Multiprocessing won't work for MAPDL so that is not possible.
      Thank you
      Erik
    • Guojz16
      Thank you for your answer @ekostson.
  • The topic ‘Parallel computing for loop in APDL’ is closed to new replies.
