July 10, 2023 at 1:27 pm
peppers
SubscriberI use the parabolic velocity profile with the expression formula and it causes reversed flow when using the outlet 'outflow' boundary condition of 100% area, whereas when I don't use parabolic I immediately enter a constant velocity at the velocity-inlet and no reversed flow occurs. why is this happening and how to solve it? I have also extended the pipe at the inlet and outlet but it hasn't worked
July 10, 2023 at 1:58 pm
Forum ModeratorDon't use outflow, it's an obsolete option and really should be removed from the GUI. Pressure outlet is the correct choice.Â
Best guess with the reverse flow is you got a negative in the wrong place in the Expression or UDF. If you initialise from the inlet which way do the velocity vectors point?Â
July 10, 2023 at 3:38 pm
peppers
SubscriberÂ
I’ve used a pressure-outlet but reversed flow still occurs.
then what do I change is this correct? i expect the flow to move to the positive x-axis but due to reversed flow, the flow is inlet to the negative x-axis
this is the expression of the parabolic formulation that I use
umax = my velocity 11.96m/s
radius = Â sqrt(x**2+y**2)
Radius = area (0.03m)uprofile = umax*(1-(radius/Radius)**2)
and this is the geometry that I analyzed where convection occurs in the middle of the box in the air flow
July 10, 2023 at 4:24 pm
Forum ModeratorÂ
If you plot uprofile in Excel what are you seeing? If you plot velocity on the inlet surface (vectors or velocity component) which way is it going?Â
The image didn't load when I was commenting. What surfaces have you got in the box region - the yellow/grey chequer-boarding suggests two surfaces in very close proximity and yellow is typically a symmetry boundary.Â
July 10, 2023 at 4:49 pm
peppers
SubscriberThe uprofile plot is in the form of a parabolic curve.
forgive me for not understanding your point. what does the velocity plot on the inlet surface look like? i expect the flow to move to the positive x-axis but the result is reversed flow, the flow is inlet to the negative x-axis
July 11, 2023 at 7:30 am
Forum ModeratorMy point is it's possible you added a negative in somewhere by accident. The other check is position: is the inlet centre at y = z = 0 ?  Please post the code, if it's an easy fix I'll tell you.Â
- The topic ‘parabolic velocity profile causes reversed flow’ is closed to new replies.
5939
1307
