January 12, 2023 at 4:46 pm
Xime54
SubscriberHi every one,Â
I want to draw with spaceclaim a reflector whose profile is a parabola. Typically define the focus, the depth, and with the "pull" tool make an extrusion to get the surface. I don't see how to simply draw this parabolic profile. Does anyone have an idea?
Thank you.
January 12, 2023 at 9:32 pm
Guilin Sun
Ansys EmployeeIf this is for Lumerical products, please refer this link Surface structure object - Simulation Object
and
Specifying object properties with an equation
Custom structure object - Simulation Object
January 13, 2023 at 6:45 am
Xime54
SubscriberThanks Guilin for your answer,Â
I was thinking of a more intuitive solution, a mechanic's method, who has to draw an object that will be produced. Creating a parabola with its focus and depth for example directly in spaceclaim, like for a circle for example:
Solidworks for exemple is very powerfull for this.Â
January 13, 2023 at 5:34 pm
Guilin Sun
Ansys EmployeeParabolic mirror is easy to do with the "surface structure obkect". You will need to have two, with the inner one to be air so to override the solid.
You can also use Solidworks and then import it.
- The topic ‘Parabolic reflectors’ is closed to new replies.
4167
1487
1338
1188
