August 26, 2024 at 1:30 pm
chrivero
SubscriberDear all,
I'm trying to simulate a simplified packed bed system in a thermal storage. To do so i considered two layers of spheres and, due to the high number of elements, i only considered one portion of the tank and i delete the sphere on the edge of the slice (even if it causes some holes but i didn't have any better idea). The problem is that when i try to mesh this message appeares: The mesh file exporter could not resolve cyclic dependencies in overlapping contact regions. Please try to Repair Overlapping Contact Regions.
What i'm doing wrong? I have two parts that are the spheres and the slice of cilynder without the spheres.
Kind regards
August 27, 2024 at 6:43 am
NickFL
SubscriberIt looks like you have not subtracted the spheres from the fluid domain. Also it should not matter if there are partial spheres cut out in your domain. Is there a symmetry in the theta direction that would allow you to pick a good "pie slice" ?
August 27, 2024 at 10:19 am
Forum ModeratorDepending on the surface proximity you may have some "contact regions" from the automatic tools. Those can return errors in Fluent as it tries to create a nonconformal interface. If you have contact regions have already done share topology/multibody part delete them and try again.Â
5989
1307
