Overtime result of multiple nodes in a single simulation result
    • Muhammad Faraz Mahmood
      Dear all,
      I am performing transient thermal analysis iBn ansys. I have selected all nodes on a plane of a solid body and want to generate results of multiple nodes overtime (Each node showing the whole time based increase in temperature from 1 till 10 seconds). But, I only get maximum and minimum result of each node instead of the step by step increment of each node.
      Can anyone have an idea how to export overtime data of multiple nodes.
      Thank you,
      Faraz
      The first image above shows overtime result of increase in temperature of just one node. I selected just one nodes and got my required overtime graph. This is what I am expecting to have.
      But in the second image above, I select multiple nodes and get results of each node with only maximum and minimum instead of overtime result for 261 nodes each.
      In the end, I just want to export overtime data of each node in excel form (If it doesn't show in ansys, then thats fine as my only concern is to have excel data of all nodes overtime)
    • ErKo
      Hi
      This should help:
      https://discuss.ansys.com/discussion/2383/print-temperatures-node-ids-and-locations-using-dpf-inside-mechanical#latest
      All the best
      Erik
  • The topic ‘Overtime result of multiple nodes in a single simulation result’ is closed to new replies.
