June 14, 2023 at 3:47 pm
zakariarahmanu
SubscriberI have an error notification in ANSYS Fluent that the overset model is not compatible with the following settings: pressure velocity coupling "simple". Anyone know this problem, and how to solve this problem? Thank you
June 15, 2023 at 11:57 am
Federico
Ansys EmployeeHello,Â
which version of Fluent are you using?
According to the 23R1 manual, SIMPLE pressure-velocity coupling should be compatible 6.7. Overset Meshes (ansys.com)
June 15, 2023 at 2:34 pm
zakariarahmanu
SubscriberI am using ANSYS Fluent 2020 R1 version. I can't change the pressure-velocity coupling, except Coupled Method
June 15, 2023 at 2:38 pm
Federico
Ansys EmployeeHad a look at the 20R1 manual, and it does say to use the Coupled scheme for pressure-velocity coupling.
Please try it and let me know if it works for you.
- The topic ‘Overset Model is Not Compatible with SIMPLE Method’ is closed to new replies.
