Overlapped lines bothering meshing
    • Rodrigo28
      Dear colleagues,
      I'm modelling a layered cube with SOLID186 in Mechanical APDL. Each layer has controlled gaps (1mm voids) in specific positions. Because of that, my geometry model ends up with coincident lines with different length, not being able to use NUMMRG,ALL to merge them before meshing. If I didn't have those gaps, I would just use NUMMRG,ALL command to merge coincident KP,lines, etc. and my mapped meshing would work great.
      I'm creating geometry with volumes using BLOC4 command. Each layer is composed of two blocs. Here are some pictures:
    • Ashish Khemka
      nnCan you try increasing the tolerance?.Regards,nAshish Khemkan
    • Rodrigo28
      I solved it!nnActually, an APDL command that almost solved it was VSBA,ALL,ALL. It unified overlapped volumes and below, but then the problem was that I still needed some extra lines in the volumes to be able to do a mapped meshing. nI ended up created extra volumes for to create these lines, and then used a NUMMRG,ALL to solve overlapped geometry.nThanks anyways for the rapid response!nnnn
  • The topic ‘Overlapped lines bothering meshing’ is closed to new replies.
