Ansys Free Student Software
Overlap Boundary Error in Mixing Tank
    • Cara Serpe
      I am tasked with modeling a mixing tank in ANSYS Discovery and doing a sensitivity analysis on parameters. I have been running into an error of a boundary overlap error when I add the fluid mixing zone around the impeller's enclosure and specify the shaft as a rotating wall boundary. I also have called out the volume enclosure. Please provide me with some insight on how to remedy this error. I have watched all of the ANSYS learning videos on this so please provide multiple solutions to this.
    • Atharv Joshi
      Hi Cara,
      You can refer to this Rotational Fluid Zone video in this playlist In-Depth - Fluids - Ansys Knowledge
      Let me know if this resolves your problem.
      Thanks and Regards
      Atharv
  • The topic ‘Overlap Boundary Error in Mixing Tank’ is closed to new replies.
