November 5, 2018 at 11:32 pm
l_smith
SubscriberI can't seem to set an output variable with two arguments. For me, I would like to calculate the group velocity from the complex propagation constant, so I would like to plot:
GV = 1/deriv(im(Gamma(1)), 2*pi*Freq)
According to the HFSS help documentation this should be possible:
deriv(quantity, SweepVariable) explicitly means derivative over the sweep variable specified in the second argument (such as "Freq").
Except I can't get 'deriv' to work with any two arguments, meaning:
deriv(Freq, Freq)
also doesn't work. 'deriv(Freq)' (one argument) works fine using the primary sweep.
Am I missing something obvious?
Thanks for any help!
note: I know I can use the group delay variable, but that's not what I want
November 14, 2018 at 10:31 am
Forum ModeratorI've checked, and this has been logged as a problem: you're (probably) not missing anything obvious.
May 27, 2019 at 1:59 am
banaful2464
SubscriberI am having the same problem. Is there any solution?
May 27, 2019 at 2:04 am
l_smith
SubscriberI never heard anything else from this, I just ended up exporting the data then using Python to perform whatever operations that I wanted.
Good luck! -
August 5, 2020 at 9:11 am
KapilGavali
Subscriberis the above problem solved?n
- The topic ‘Output Variables with two arguments (i.e. deriv) in Ansys HFSS 19.1’ is closed to new replies.
3832
1414
1193
1100
1015
