July 13, 2023 at 8:23 am
kseyksey039
SubscriberHello, how can I only output the XYZ coordinate K file of a specific node.
ÂÂÂ
July 13, 2023 at 1:40 pm
Armin
Ansys EmployeeHi Rex,
Could you elaborate a little more?
Is this for LS-PrePost? Are you trying to extract x, y, z coordinate of a particular node of a model? -
July 14, 2023 at 7:08 am
kseyksey039
SubscriberYes, this is Ls-PrePost, I just want to extract the xyz coordinates of the black area -
July 17, 2023 at 4:43 am
kseyksey039
SubscriberCould someone please answer this question? -
July 17, 2023 at 2:06 pm
Armin
My impression is that you're looking for some ways to automatically select the region of interest to extract x, y, z of nodes (as opposed to manually selecting the region).
This should be possible through scripting in LS-PrePost. I have not tried this, but I found the course below that might be of help to you. The course is on Ansys Learning Hub (requires subscription). You should be able to access more resources if you look up LS-PrePost Scripting online.
LS-DYNA | Advanced Practices - Ansys LS-PrePost Advanced (sapjam.com)
- The topic ‘output problem’ is closed to new replies.
6585
1311
