December 2, 2024 at 3:28 pm
December 3, 2024 at 12:23 pm
Forum ModeratorSee if anything shows up when you check Task View panel.Â
December 3, 2024 at 12:40 pm
December 3, 2024 at 2:36 pm
December 3, 2024 at 3:13 pm
dingqian.ding
SubscriberThanks for your reply, Rob!
The issue is the top menu panel and outline views are all disappeared. I carefully checked and I didn't find that either top left window or top right window.
 I do remember that I clicked something when I set up Fluent last week and top menu panel and outline views are disapeared after that, before that everything works perfect. I update two new figures. Do you know how to solve this issue?
Thanks a lot!
December 3, 2024 at 3:36 pm
Forum ModeratorTry https://innovationspace.ansys.com/knowledge/forums/topic/missing-ribbon-and-menu-when-i-open-fluent-both-ribbon-and-blue-file-menu-that-usually-sits-above-it-are-missing-how-can-i-bring-these-back/Â
December 3, 2024 at 6:21 pm
dingqian.ding
SubscriberHi Rob,
I was able to enable the outline view before I saw your link.
But the menu bar (ribbon) still is inactive even if we tried your link and we also tried another link:https://innovationspace.ansys.com/forum/forums/topic/ribbon-window-disappeared/?template=rocky but the ribbon still not be active. Since our cluster is running on the Linux system, do you have any other solution? The link you sent to me is based on the windows system. The following figure is updated screenshot.
Thanks a lot
Ding
December 4, 2024 at 10:04 am
Forum ModeratorCan you run Fluent in standalone mode?
5734
