outlet temperature
    • _1billy
      hello, i have cylinder which supposed to heat flux with inlet water=25 c and outlet 0 gage pressure
      now i want to determine outlet temperature of water
      1- what is input here ?
      The clue is "backflow", the temperature there is only used to determine the temperature of any fluid entering the domain from that surface.
      On a flow boundary I'd use mass weighted and on a solid boundary area weighted. Have a look at the definitions and you tell me why.
    • _1billy
      thank you , but now in my case should make value of backflow temp = 0 or leave it as default=300 ??
      Zero Kelvin would be bad, if there's no back flow leave it at 300K.
    • _1billy
      thank you
      You're welcome.
Viewing 5 reply threads
  • The topic ‘outlet temperature’ is closed to new replies.
