March 9, 2018 at 7:49 pm
cblank
SubscriberWhen I do a particle analysis, it would appear that the particle are not existing the system. Is the outlet constraint a wall?
I want to make sure that the simulation is not building up pressure on the outlet.
March 9, 2018 at 10:19 pm
Brian Bueno
Ansys EmployeeCyril
The outlet does act as a wall for particles. However, since I have not seen your model, try the water flow sample from the Discovery Live start page. I believe this shows the same behavior you described.
You can also adjust the results to show pressure instead of velocity, but the particle display will not be available.
- The topic ‘Outlet constraints’ is closed to new replies.
Ansys Innovation Space
1333
1168
1090
1014
