May 6, 2025 at 11:23 am
sarathaj
SubscriberI am working a thermal Analysis of a Motor using MRF rotating at 5000 RPM And I have modelled Air domain ( Sphere) to monitor the fluid flow. It is a natural convection. I applied heat loss to the componenets in the Motor. Bu when I apply pressure outlet at the surface of the Sphere ( air domain- fluid) lot of heat emitted to the atmosphere resulting in the lesser tempearture on the components.
Should I apply fixed Wall tempearture ( ambient temperature) or HTC & temperature to the sphere boundary ?  -
May 8, 2025 at 9:05 am
Essence
Ansys EmployeeHello,
Can you share a screenshot of the domain for better understanding?
May 8, 2025 at 9:19 am
sarathaj
SubscriberÂ
I am Sorry , I cannot share the screenshot because of confidentality.Â
I am provide bit more clarityÂ
A large sphere shaped air domian acting as a fluid ( to monitor velocity when motor rotates), |A geometry contain both motor and stator, and applied MRF to the rotar region and the heat loss to few components ( both rotor and stator).
I ran steady state first ( only flow and turbulent on, energy off) to get flow field converged, then turned on energy equation ON during transient analysis ( flow and turbulent off) and applied heat loss to the geometry.Â
here I applied the outer surface boundary of the sphere as pressure Outlet.Â
Note- It is a Natural Convection.ÂÂ
May 8, 2025 at 10:27 am
Essence
Ansys EmployeePlease run the flow and turbulence equations with energy equation since the heat supplied or extracted impacts the flow and turbulence.
May 8, 2025 at 10:41 am
sarathaj
SubscriberYou mean during the transient analysis ( to turn on all energy, flow and turbulent equaiton) ?
May 8, 2025 at 11:40 am
Essence
Ansys EmployeeYes.
May 8, 2025 at 1:08 pm
sarathaj
SubscriberThank you, I will try and let you knowÂ
May 8, 2025 at 2:04 pm
Essence
Ansys EmployeeSure, please.
May 10, 2025 at 7:50 pm
sarathaj
SubscriberHIÂ
I ran with all three equaitons, It gives the same result ( No changes )Â -
May 12, 2025 at 7:18 am
Essence
Ansys EmployeeI see. You can always try to open a new Support case in Ansys customer support portal. This will help us to suggest you the points more effectively.
May 12, 2025 at 7:19 am
sarathaj
SubscriberSure, Thank youÂ
3044
971
863
858
792
