July 3, 2024 at 7:50 pm
ALEXANDRE COSTA
SubscriberHello,Â
The original discussion was :Â October 29, 2019 at 5:40 pm : OSI and TWASS
It is happening for me the same error message as posted in that thread by Paras25 (not solved, and thread closed :-(Â :
... The fl process could not be started . Seems the error occurs when the EXECUTE_AT_END function is called during the transient calculation.Â
DrAmine briefly mentioned "disable node values" in the discussion. How can I do that? Maybe that is the cause of the errror.
I am using visual studio 2022 and the udf is compiling fine : compile(ok), 5 udms allocation(ok), hooking(ok)Â and execute(failing)
Any help would be very welcome.
July 4, 2024 at 10:12 am
Forum ModeratorWhat does the UDF do? Ie does it change something in the model or just report a value?Â
- The topic ‘osi udf’ is closed to new replies.
5624
1885
1403
1298
