September 6, 2023 at 1:08 pmdimitri.goethalsSubscriber
Hi,Â
One of our customers can't use ordinate dimensions in the detail tab when working in French language (default setting for him as he has a French OS).
In Enlish it is working.
I have added his user configuration as well.
What can be done here?
He is using the latest version of Ansys SpaceClaim.
Regards
Dimitri
September 7, 2023 at 5:19 amDevendra BadgujarForum Moderator
Hello Dimitri,
Let me check and get back to you on this.Â
Regards.Â
September 8, 2023 at 10:07 amDevendra BadgujarForum Moderator
Hello Dimitri,Â
This is a known issue for french language and we have notified the developers regarding this. For now please from the Design, minimize the ribbon with the shortcut Ctrl+F1 or click on the arrow at the top right and you should be able to use the ordinate dimesnions.Â
Regards
DevendraÂ
- The topic ‘Ordinate Dimension no longer available’ is closed to new replies.
Ansys Innovation Space
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- Crash by using Script Editor
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Temperature’s Distribution not available in Refine Mode ?
- Thermoelectric Cooler Model
513
488
225
209
