TAGGED: export, import, import-export-ascdm, ipc2581, orcad
March 9, 2022 at 11:46 am
mmuk
SubscriberWhen using PCB Editor, I export my PCB design as IPC2581, following the online tutorial. But sometimes (not always!) when I import this to Ansys, I get just two empty circles (looks like a 2-pin header footprint without the edge box), and nothing else. Does anyone know why this happens? Is it an issue with the exporting from OrCAD or the importing to Ansys?
March 11, 2022 at 4:29 pmDan Dv
Ansys EmployeeIt can be hard to say exactly why the import fails. If you try and open the IPC2581 file in question in another tool such as one of the free viewers, are they able to open a visualize the geometry correctly?
I think the general guidelines when exporting IPC2581 out of the PCB editor are use the options:
IPCÔÇô2581 = Revision B
Functional Mode = USERDEF
Select All Check Boxes Except: Export Cross Section Data Only
I've also seen cases where the fix for issues like this is to update to the latest hotfix of PCB Editor.
Viewing 1 reply thread- The topic ‘OrCAD IPC2581 Export not working?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
Top Contributors-
3862
1414
1221
1118
1015
