Electronics
Electronics
OptiSLang MotorCAD single instance integration
    • nkb221
      I've generated an Optislang project from the MotorCAD interface and I've run it without any parallel instances. I've found that MotorCAD has very low CPU usage a design takes roughly an hour to compute. This normally takes 10 mins max. if doing manually. Is this a known issue? Any hints on what could be going wrong?
    • Navya Chode
      Hi nkb221,
      It appears that the question you've asked is being addressed in the post below. If you have any additional questions, feel free to continue the conversation there.
      Optislang MotorCAD HPC integration
      Navya
      • nkb221
        Hi Navya,
        That is incorrect. The issue has still not been addressed.
