February 25, 2024 at 12:40 pm
Md_Salem
SubscriberHello everyone,
I am trying to optimize the thickness of a piezo patch attached to a plate structure.
The geometry is done using DesignModeler. The optimization is done through design exploration in ANSYS 22R1.
I used the APDL code to assign a harmonic analysis of the Piezo patch under a voltage load. and here is a part of it:
ESEL,S,ENAME,,226
NSEL,R,LOC,Z,1e-3Â Â Â Â Â Â Â !1e-3 is the initial thickness of the Piezo patch
D,ALL,VOLT,100Â Â Â Â Â Â Â Â Â Â ! 100 is the initial voltage load
and so on until the end of the code.
The problem that I faced is that I need to parametrize both thickness (initially 1e-3) and voltage (initially 100) such that [VOLTAGE/THICKNESS < known fixed value].
Would anyone help me with that problem?
Regards
February 28, 2024 at 7:00 pm
wrbulat
Ansys EmployeeI'll assume three things: (1) you parameterized the thickness of the piezo transducer in Design Modeler, (2) the APDL you provided is in a command object under the Analysis branch, and (3) you are applying the nonzero voltage on a planar surface (the maximum z coordinate of the piezoelectric body).
In this scenario you could use the following code:
esel,s,ename,,226 ! SELECT SOLID226 ELEMENTS
nsle            ! SELECT NODES USED BY SELECTED ELEMENTS
*get,zmin,node,,mnloc,z ! ZMIN = MIN Z COORD OF SELECTED NODES
*get,zmax,node,,mxloc,z ! ZMAX = MAX Z COORD OF SELECTED NODES
nsel,r,loc,z,zmax      ! RESELECT NODES AT Z=ZMAX
t_piezo=zmax-zmin    ! T_PIEZO = THICKNESS OF PIEZO (Z DIRECTION)
d,all,volt,arg1*t_piezo ! SET VOLTAGE EQUAL TO ENTRY IN ARG1 FIELD (in Details) TIMES T_PIEZO
allsel  ! ENSURE ENTIRE MODEL IS SELECTED BEFORE SOLVING
I think you can paramaterize ARG1 by checking a box adjacent to the field in Details. I don't know DX, but I would think it's possible to define allowable limits on the values of parameters in the application. If so, you could set a limit on ARG1 (which equals VOLT/T_PIEZO) so that it cannot exceed this "known fixed value" you mentioned. I hope this helps!
Best,
Bill
February 29, 2024 at 2:29 pm
Md_Salem
Subscriberappreciated
- The topic ‘optimize thickness of piezo patch’ is closed to new replies.
3572
1193
1076
1063
952
