November 26, 2022 at 4:34 am
November 28, 2022 at 5:48 pm
Guilin Sun
Ansys EmployeeIn general, if the data matrix size changes during the sweep, or if you sweep wavelength/frequency, such issue can occur.
Please check what do you sweep, and if the R monitot is changed during sweep?
If problem still exists, please paste some screenshots of your settings, such as the monitor, and the sweep etc.
July 18, 2023 at 6:04 pm
July 18, 2023 at 6:25 pm
Guilin Sun
Ansys EmployeeUsually same issue the same solution. Make sure each sweep will not cause the monitor data matrix dimension change.
It seems your software is old version. The new version has clear warning (xx is the field component in the case below)
The results from the individual stimulations of '::model::monitor::XX' are of different sizes and could not be saved.
July 18, 2023 at 6:29 pm
haeri.p
SubscriberThe monitor is fixed and of the same size and does not change during sweep.
July 18, 2023 at 6:30 pm
haeri.p
SubscriberÂ
And my other colleagues are using the same version of software and optimization sweep without any problems. I discussed with them and I use the same way they use it.
I tried running a simple sweep and it worked fine. It's just the optimization sweep that's causing the error of incorrect size.
July 18, 2023 at 10:23 pm
Guilin Sun
Ansys EmployeeIt is less likely that the sweep its self cause any issues otherwise all the sweeps will have issues. If you cannot duplicate the error, it will be more difficult for us. Probably you can delete the current sweep object and then add a new one again, and test if it works.
Please check the warning message and then check what cause it as I cannot read the warning message from your screeshot.
- The topic ‘Optimization’ is closed to new replies.
6845
1343
1152
