January 3, 2024 at 2:52 am
pengzheng97
SubscriberHi, I met a problem when I learn the case ""Optical PAM4 transceiver" in the case library"
https://optics.ansys.com/hc/en-us/articles/360042322694-Optical-PAM4-transceiver
I add an "Optical Oscilloscope" as the picture to view the optical signal after pam4 modulation, and I noticed the signal have some problems: There will be some overshoot at the edge of the modulated signal strength change, resulting in some "spikes" in the signal. Is this correct? Is there any way to reduce this?
Thanks, wish for your reply :)
January 3, 2024 at 7:44 pm
GWANG
Ansys EmployeeHi pengzheng97,
Thank you for the post. This effect of spikes is normal and you can add a filter after the modulator to remove this effect.
Hope this can help.
January 8, 2024 at 8:46 am
January 10, 2024 at 1:49 am
pengzheng97
SubscriberHi,Guanhui Wang, is there any method to solve the problem? Or any other way to modulate PAM4 signal withou these overshooting peak.
Really need your help, wish your reply, thanks
- The topic ‘“Optical PAM4 transceiver” in the case library’ is closed to new replies.
