Photonics
Photonics
Optical Modulator Measured
    • spa3269.starrynight
      Hello.
      I have a problem about the optical modulator measured element in Lumerical Interconnect. I want to design an asymmetric mach-Zehnder Interferometer and use an optical modulator conncted to DC source to make length difference between two arms. Despite of voltage change in DC source, I never see any shift in optical transmission and, all transmission spectra Vs. frequency or free spectral range are the same. How can I solve this problem and make one phase controbale mach-zehnder circuit? I attach the diagram of my design in interconnect for more detail? Thanks.
      MZI circuit
    • Kirill
      This topic has been moved to the Photonics  forum. Thank you!
    • Dev
      Hello Are you using Optical modulator element ? Most likely its not modulating phase wit DC input. can you please chek, the voltage in DC source. If the modulator isn't configured properly (e.g., missing VÏ€, length).
      INTERCONNECT: Enabling time and frequency domain simulation of photonic integrated circuits with microring modulators
      Can you povide screenshot of properies of OM1 and DC-1?
      Thanks
        Hello.
        Thanks so musch for your attention. I attach the properties of two options you want. Alternatively, I used the N-port S-parameter element instead of splitter element, and then enter our s-matrix obtained from MMI simulation. Fortunately, this showed clear change in transmission spectrum. But I do'nt know this process is correct or not. That's kind of you if you bring me a solution in order to use these results in the next MODE solution simulation.
    • Dev
      Thanks for sharing the screenshot.
      It looks like you're heading in the right direction.
      I’m a bit unclear about this part: "That's kind of you if you bring me a solution in order to use these results in the next MODE solution simulation."
      Could you clarify what you mean? Also, have you already extracted the S-parameters from MODE?
