October 5, 2024 at 2:08 pm
titouan.reynaud1105
SubscriberHello everyone,Â
I am new to the software, I am trying to set up a simulation for my FSAE race car, but when I want to create an enclosure, an error concerning non-manifold bodies occurs.ÂBut i have checked and my body is full (not hollow), and when I use the Too-Analysis fault for bodies nothing happens..
Can someone help me out ?Â
Thank youÂ
October 7, 2024 at 11:00 am
Forum ModeratorNon-manifold tends to trigger when you have surface-surface contact with zero area. As an example where a cylinder contacts a flat surface: eg the bottom of the tyre. If you flatten the bottom of the tyre a bit (highly precise engineering dimension unit) does that help?
1306
