August 20, 2018 at 4:33 pm
jdfrad
SubscriberI just recently uninstalled Ansys 18.1 and downloaded Ansys Aim 19.1. Everything downloaded well, but when I click the link to Ansys Aim i get this message:
I have uninstalled then reinstalled the program and I get the same error. So, then I erased everything on my computer that had to do with ansys and re-downloaded it and then reinstalled it and I get the same issue. Any thoughts?
August 20, 2018 at 4:54 pm
peteroznewman
SubscriberDid you "Run as administrator" setup.exe?
August 20, 2018 at 4:59 pm
jdfrad
SubscriberYes
August 20, 2018 at 10:27 pm
Karthik Remella
AdministratorHello,
It seems like some kind of a graphics issue. What kind of graphics card are you using?
Thank you.
Best Regards,
Karthik
August 21, 2018 at 2:06 am
jdfrad
SubscriberHello,
I am running an Intel(R) Graphics Card
August 21, 2018 at 2:43 am
Karthik Remella
AdministratorHello,
Could you please go through this link here and make sure you have the necessary infrastructure to run AIM 19.1 on your system?
https://www.ansys.com/solutions/solutions-by-role/it-professionals/platform-support
Thank you.
Best Regards,
Karthik
August 21, 2018 at 2:05 pm
jdfrad
Subscriber Karthik,
Thank you for the link. I have read the entire page and did not see an enumeration of what capabilities my processor, gpu, etc. should have. I did see that there are a number of gpus that have been tested and are supported by Ansys. Does that mean that these are the only cards that Ansys can run on, or are these just a loose recommendation?
Thank you
August 21, 2018 at 2:50 pm
DrAmine
Ansys EmployeeThe document contains the cards we have tested and that is why are named "certified". Moreover there is a note in the documentation stating that the use of integrated Intel graphics cards is not recommended. These cards are typically found in lightweight laptops or notebooks, and are known to have OpenGL incompatibilities resulting in display issues in AIM
August 21, 2018 at 3:21 pm
tsiriaks
Ansys EmployeeHi jdfrad,
I agree with above that the graphics card is the issue here; however, in a rare occasion, we've seen some cases with untested graphics card that got it to work by updating the graphics driver to the latest available from the vendor website. If that doesn't help, unfortunately, the only way to make sure that it works is to use one of those tested graphics cards.
Thank you,
Win
August 21, 2018 at 3:37 pm
peteroznewman
SubscriberHi jdfrad,
Best if you can upgrade to a certified card, but while you are waiting, see if SpaceClaim 19.1 will start.
From the Windows Start Menu, under ANSYS 19.1 select SCDM 19.1 and see if SpaceClaim starts.
If it does, there are some Options to select a different Renderer. You can get more details after you see if it starts at all.
Try this after you have upgraded to the latest driver for your Intel graphics card.
Peter
August 22, 2018 at 1:03 am
jdfrad
SubscriberHi everyone,
Thank you for all of your responses. I will try to update my driver followed by trying SpaceClaim. If that does not work I have a computing lab on campus that has some available computing time set aside for students so I can go there.
Thanks Again,
Jacob
August 23, 2018 at 1:21 am
Karthik Remella
AdministratorHello,
Please let us know what you find.
Good luck.
Thank you.
Best,
Karthik
August 23, 2019 at 9:25 pm
Cruze86
SubscriberHello, I am having issue while opening, it shows the error fortran severe (47) and it is crashing. Can anyone help me with this problem? My graphics card is gtx 1050ti and cpu is intel i5-8300h. I am using the student version. -
August 24, 2019 at 12:24 am
tsiriaks
Ansys EmployeePlease create a new thread and post the screenshot of the issue.
Thanks,
Win
- The topic ‘Opening Issue’ is closed to new replies.
5664
1890
1419
1304
