3D Design
3D Design
Opening a “.dbs” file in v19.3
    • Ramy
      I have a ".dbs" file. I used to open those files by  earlier Fluent versions (such as v16). But I am trying to open it in the design modeler of Fluent V19.3 and it gives an error saying that it is not compatible with the interface!
      How can I open it?
      Thank you.
      Ramy
    • Keyur Kanade
      can you please check importing it in SpaceClaim.
      Keyur
    • Ramy
       It didn't work out. It gave the same error.
    • Keyur Kanade
      if you have v16, you can import in it and save file. then open it in latest version.
      please try latest version at
      https://www.ansys.com/en-in/academic/free-student-products
      if you have GAMBIT, please check if you can export step or iges file and import it in SpaceClaim.
      If this helps, please mark this post as 'Is Solution' to help others.
      Keyur
  • The topic ‘Opening a “.dbs” file in v19.3’ is closed to new replies.
