open channel flow with breakwater
    • Shafaq
      Hi, I'm having trouble with Ansys Fluent. I have modelled a breakwater in an open channel flow. However the breakwater is not stopping the wave. I have attached a picture to show the problem
      Build a bigger breakwater?
    • Shafaq
      Thank you for your reply.  I have tried that, is there anything else I can try ?
      How have you created the blockage? I ask as the free surface looks to ignore it, and as it ought to be a void (no mesh), that doesn't make sense.
    • Shafaq
      Hi yes, I have created the blockage, Do you know why the free surface is ignoring it ?
      Yes.
      Please read up on Boolean Subtract. In isothermal models you only tend to model the fluid bit, you've got overlapping mesh and the box isn't doing anything other than confusing the results.
    • Amine Ben Hadj Ali
      It might be that the blockage is ignored as you are initializing with the wave. Carry out the run and tell us what you are seeing.
    • Shafaq
      Do you think its a problem initializing with the wave as it's not considering the blockage?
      I'm unable to simulate the wave by creating a moving wall at the end of the tank as I've had complications with UDF  and I'm also using a university computer.
      I've attached a picture after the run below
      Looking at that result, the wave has gone over the blockage and you need to check the back flow on the outlet to make sure the water can leave. The water-air interface also looks diffuse so you may also need to refine the mesh in that area.
      • Mohamed Elalidy
        How to make open channel flow with breakwater please?
    • ErKo
      HI
      Can you please open up a new discussion and publish it in the fluids forum.
      /forum/forums/forum/discuss-simulation/fluids/
      Thank you
      Erik
Viewing 9 reply threads
  • The topic ‘open channel flow with breakwater’ is closed to new replies.
