April 6, 2024 at 8:25 am
ibrahimallam087
SubscriberHi, im trying to simulate river problem i got the river ground data from measurments, put it in excel file and i drew the river in spaceclaim the river length is 1000 m and its width is 500 m and the water depth is 9.8 m i put air height above water as 10 m ...and modeled it using VOF openchannel flow .. the problem is that the solution not converging and the result contours shows that the air and water are mixing ( The image below indicates the result)
April 8, 2024 at 11:30 am
Forum ModeratorHow many cells are in the z (up) direction and what is the cell aspect ratio?
- The topic ‘Open Channel Flow River simulation problem’ is closed to new replies.
Ansys Innovation Space
1057
1051
965
942
