Preprocessing
Preprocessing
Only one mesh generation method is shown
    • sosnin1992
      Hello, friends!
      I started to learn Ansys recently using student version. During mesh generation in Ansys Mechanical I only see automatic method that can not be switched to hex dominant, tetrahedrons, sweep, etc. Just want to make it clear is that Ansys student version limitation or I do something wrong?
    • Keyur Kanade
      Please post the questions in appropriate category. Moving this question to other category to get better response.
      Moving to meshing.
      this is not limitation.
      can you please try on a simple geometry like cube?
      if required, you may need to re-install it.
      please use 2020R1.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
  • The topic ‘Only one mesh generation method is shown’ is closed to new replies.
