November 25, 2024 at 11:24 pm
lis29
SubscriberHi, I'm consistently having trouble getting this sim to converge. I've attached a link to the archive file here. Here's the basic information about the sim:
This is the general sim geometry.Â
The model consists of multiple parts held together by solid body bolts with simplified cylindrical shafts and T-nuts
Realistic contacts:
Nuts are bonded to bolt shafts with a tiny gap in between
Bolt head contacts with gussets are frictional, 0.2 coefficient
Nut contact with beam is frictional, 0.2 coefficient
Bolt shafts to gusset and beam walls is frictionless (basically the bolt hole)
Parts held together by physically modeled bolts have frictional contacts between them if they’re directly connected by a fastener and frictionless otherwise
All parts without physically modeled bolts are bonded
Boundary conditions are two fixed supports where the model is cut off, plus a planar symmetry boundary condition
500N force upward
Fixes attempted to achieve convergence
Gradual load stepping from 150N to 500N over 8 steps
- Total number of steps is 10, first two left without load to allow contacts and bolt pretensions to initialize
Increased substeps to 250 initial, 100 minimum, 500 max
Removing mesh controls and using a very fine mesh
Fixed contacts in contact tool under connections
Large deflection on and off
- Increased Newton-Raphson residual value to 4 and increased mesh density at the NR maxima after a failed solve
- Used modal analysis to vet contacts
- No parts flew off and there were no 0 values for modes so this looked fine
Any advice would be greatly appreciated!
November 26, 2024 at 7:18 am
erik.kostson
Ansys EmployeeÂ
Hi
Ansys Employees are not allowed to download any files.
Perhaps other forum members might be able to chime in here and help.
We can though suggest some of our free courses that deal with this type of analysis:
https://innovationspace.ansys.com/product/get-started-with-ansys-mechanical/
https://innovationspace.ansys.com/product/contact-mechanics/
https://innovationspace.ansys.com/product/preloaded-bolted-joint-analysis/
https://innovationspace.ansys.com/product/connecting-parts-together/
https://innovationspace.ansys.com/product/modeling-the-bolt-and-preload/
https://innovationspace.ansys.com/product/connecting-bolts-with-assembly/
https://innovationspace.ansys.com/product/fundamental-topics-in-contact/
All the best
Erik
