June 28, 2023 at 11:34 am
Pratik Ganorkar
SubscriberHi,
I am using ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK, is there any way to visualize the extent of tiebreak contact breakage like finge plots of stresses and history variables.
Thanking you
Pratik Ganorkar
MTech, IIT Goa (2021-23)
June 30, 2023 at 12:41 pm
Ram Gopisetti
Ansys EmployeeHi, onw way is to use SPR and MPR in the ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK card and use S=INTFOR in the run expression you can get the contact gap contours in intfor, check the binout for RCFORC for tie area and z_force curve as indicater when the tie got break.
cheers, RamÂ
- The topic ‘ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK visualization’ is closed to new replies.
1885
1404
1303
