One or more objects may have lost some scoping attachments during the geometry update. You can ident
August 7, 2020 at 7:36 am
kirstenbraun
SubscriberHello,
When importing my geometry into ANSYS Mechanical i get this error: "One or more objects may have lost some scoping attachments during the geometry update. You can identify these tree objects by filtering the tree using the Scoping option set to Partial.". However, when changing tree to "Scoping" and "Partial" nothing appears under the tree besides the "Project".
How can I resolve this issue if I dont know what the problem geometry is? Any recommendations?
August 7, 2020 at 9:22 amAshish Khemka
Forum ModeratornnThe message above indicates that wherever you have scoped geometries be it in contacts or boundary conditions, one of the objects could not scope it to all the geometries it was scoped to. Try right-clicking on the message and see if you have to go to problematic object, if not, go to the objects and check the scoping manually. If you have not created contacts manually, delete existing contacts and recreate them automatically.nnHope this helps.nnRegards,nAshish KhemkannApril 22, 2021 at 10:58 amkeshavkothari48
SubscriberIt is not showing any objects !nnNovember 11, 2022 at 9:33 ameashwarraaj
SubscriberAshish Khemka sir , I also encountered such error and also I followed your steps told by you , But again this error come is there any other methods are there to solve this issue because my Cad is little complex. #oneormoreobjects #Scopingattachments
January 13, 2023 at 11:24 amXiaohai Wang
Subscriber如果多次更新还是失败,可以尝试关掉,重新启动软件;甚至于新建项目
Viewing 4 reply threads- The topic ‘One or more objects may have lost some scoping attachments during the geometry update. You can ident’ is closed to new replies.
3572
1188
1076
1063
952
