February 19, 2021 at 8:32 am
michutorres
SubscriberHello all,
I am trying to mesh to import bodies by default but an error appears that says: "one or more entities failed to mesh". Does anyone know how to solve this problem?
Thank you
February 19, 2021 at 8:51 am1shan
Ansys EmployeeYou may try to reduce the element size below the minimum feature size of your geometry. Also turn capture curvature & capture proximity to "YES"(click on mesh and you would find those options under sizing).
Regards Ishan
February 27, 2021 at 8:03 ammichutorres
SubscriberThank you for your help. It was very useful!
I have another question: when introducing the properties of a fluid in Ansys Fluent, what is the Pure Solvent Melting Heat (j/kg)?
Thank you
March 1, 2021 at 4:36 pmRob
Forum ModeratorPlease post in a new thread in the Fluids section
Viewing 3 reply threads- The topic ‘One or more entities failed to mesh’ is closed to new replies.
3190
1025
962
859
798
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
