August 28, 2024 at 7:51 am
itoito405231
SubscriberI am planning to perform a coupled magnetic field analysis and structural analysis of a flexible magnet. However, I am not sure if the magnetization direction also changes with the deformation of the structure, so I asked this question. I would appreciate it if you could tell me.
August 28, 2024 at 1:41 pm
MirandaH
Ansys EmployeeHello, the magnetization direction is input quantity in Maxwell, it won't change with the deformation of the structure. -
August 29, 2024 at 12:03 am
itoito405231
SubscriberThank you for reply.
Then, how can I perform a coupled magnetic field analysis and structural analysis of a deforming magnet?
August 29, 2024 at 6:41 am
ErKo
Ansys EmployeeWe can use solid226 coupled field elements (AZ,UX,UY,UZ dof) with nlgeom on, and the magnetization vector direction will be updated.
(There is no example in the help manual so it is very hard to set this up if you do not have any experience with MAPDL)
Since like in Maxwell we mesh (MAPDL) the air domain around the magnet, we can only have small deformations of the magnet, otherwise air elements will distort too much and solution will fail/stop (due to high element distortion).
If you have very large deformations (structure) then we can not do this.All the best
Erik
5899
1306
