February 2, 2024 at 6:19 am
February 2, 2024 at 11:37 am
Akshay Maniyar
Ansys EmployeeHi Pavan,
Thank you for posting on the forum. I guess you have multiple posts and all the information is scattered. It will be very difficult to understand your issue and help to resolve the issue. I will close all other posts and add the data to this post. Please add some description about your model, so that it will be easy to understand.Â
Thanks,
Akshay Maniyar
February 2, 2024 at 12:21 pm
peteroznewman
SubscriberThanks Aksay for compiling the multiple posts. Can you delete those other posts so this is the only post?
Hi Pavan,
It seems the model is not converging in load step 1. Please show the Step Controls for step 1. I expect you need to use more initial substeps in step 1.
-Peter
February 2, 2024 at 12:36 pm
Akshay Maniyar
Ansys EmployeeÂ
Hi Peter,
Thanks for checking. I have closed the other posts so no one else can edit or post on them. We can continue with only this compiled post.
Thanks,
Akshay Maniyar
February 6, 2024 at 5:39 am
pavan kumar
SubscriberHello,
I want to do structural analysis of oilpan with sealingÂ
oilpan is plastic material with non linear properties and sealing also rubber material with nonlinear properties
below is the image of components
for ribber 1mm element size is used and for plastic 4mm element size is used Â
between the component frictional contact is used below is the image for concact definition
nonlinear adaptive mesh comand is used for rubber partÂ
below is the image is showing the command for analysis
two step analysis is to be performedÂ
step one is 0.1MPa internal pressure is applied with gravityÂ
below is the image for step 1 input
step two is tempature is increased from room temp to 120 degree celcius with gravityÂ
below is the image for step 2
while running the simulation this is first error i got below is the error image
i got this error after equil iter 2 completedÂ
after this error bisection 1 occures
model converged some itrations and bisection 2 occuresÂ
after bisection 2 again model got converged i got second error after some time of while running model below is the error image
after this bisections are occures and converged some iterationsÂ
at last i got this error below is the error image
below is the image of step 1Â
below is the image of step 2Â
please have a look and do the needfulÂ
Thanks
Pavan kumar Â
February 6, 2024 at 12:25 pm
peteroznewman
SubscriberHi Pavan,
Delete or disable the Nonlinear Adaptive Region. You don't need that.
Please show the Engineering Data for the rubber material. Did you use a Hyperelastic material model? You do need that.
Some additional settings are needed to help a hyperelastic material converge.Â
Here are my five must do items to achieve convergence in hyperelastic material undergoing large deflection.
February 6, 2024 at 12:56 pm
February 6, 2024 at 1:17 pm
pavan kumar
Subscriberabone is the material dataÂ
please have a lookÂ
thanksÂ
PavanÂ
February 6, 2024 at 7:41 pm
peteroznewman
SubscriberYou need to fit a Hyperelastic Material Model to the Hyperelastic Experimental Data you have available.
Right now, you only have a Linear Elastic Material model that does not represent the material behavior that you have experimental data for.
I suggest you take some of the free courses in Hyperelasticity.
/courses/index.php/courses/topics-in-hyperelasticity-using-ansys-mechanical/
/courses/index.php/courses/hyperelasticity/
Several other resources are listed here.
February 7, 2024 at 11:16 am
pavan kumar
SubscriberHello Peter,
i gone through the link what you said but still i am getting same type of error here is the error image
before i going throught the link what you said i used the hyperelastic material here is the image
after gone throught the link what you said i changed the type of material i used 2nd order here is the image
but still i am getting same type of errorÂ
please do the needfulÂ
ThanksÂ
PavanÂ
February 7, 2024 at 3:23 pm
peteroznewman
SubscriberDid you create a 1 element unit cube to plot the results from an Ogden 2nd Order model against the Experimental data? Please show those two curves overlaid.
February 8, 2024 at 5:10 am
February 12, 2024 at 1:06 pm
pavan kumar
SubscriberHello,
i tried all the possible ways to converge the model but i am not able to do,please have a look and do the needfulÂ
February 12, 2024 at 10:45 pm
peteroznewman
SubscriberPlease rescale the Y axis. The red line goes down so far, while the blue dots look like they are at 0.
February 15, 2024 at 7:24 am
pavan kumar
i am using this above type of rubber material and i tried all the possible ways to converge the model but not able to doÂ
i am getting same error here is the error image
and after here i attached the convergence graph
and at last i got this type of error here is error image
and here i attached the load step 1 image
i am not understanding where i made mistake can you please have a look and do the needfulÂ
thanksÂ
pavan
February 16, 2024 at 1:01 am
peteroznewman
SubscriberIt nearly converged but there were 2 bisections. You should increase the Initial and Minimum Number of steps by a factor of 4.
You should also insert a Command Object in the Model with the command
NEQIT,100
This command tells the solution control logic to keep trying for up to 100 iterations before doing a bisection instead of the default 26 iterations.
I previously gave you a link to a YouTube video with the important Keyopts to use for Hyperelastic Materials. Did you follow that advice?
February 16, 2024 at 7:04 am
pavan kumar
Yes i tried the Keyopt for Hyperelastic Materials but that also not worked, then i tried this above mentioned material propertiesÂ
ok i will try this NEQIT,100Â
Thanks
Pavan Â
- The topic ‘oilpan and sealing’ is closed to new replies.
5799
