August 26, 2025 at 1:51 pm
pradhan.5
SubscriberHi,
Does odb++ or IPC-2581 file exported from KICAD 9 contains all the required files needed for Thermal analysis of a PCB in SIwave and Icepack?
Any suggestions would be of great help.
Thanking in advance.
August 26, 2025 at 11:25 pm
Takeshi Itadani
Ansys EmployeeAEDT does not support ECAD data exported from KICAD.ODB++ is supported by the following software.Altium Designer R10 and later
Mentor Expedition EE7.9.1 and later
Mentor PADS 9.4 and later (v7 and v8 ODB++)
Zuken Cadstar 12.1 and laterIPC2581 is supported when exporting from Cadence SPB 17.4 or later. -
August 27, 2025 at 5:55 am
pradhan.5
SubscriberThank you for your valuable input.
August 27, 2025 at 6:54 am
pradhan.5
Subscriber -
August 27, 2025 at 7:32 am
Takeshi Itadani
Ansys EmployeeThis is a DCIR analysis without any passive components mounted. Nets that are not connected by R or L are treated as having no continuity. If you want to analyze the characteristics of passive components as well, please set up passive components in SIwave.
Viewing 4 reply threads
Ansys Innovation Space
1388
1188
1100
1015
